Change active palette tool, when mouse cursor hover on graph cursor
I want change cursor type when mouse hover on graph cursor, but I get error 1077.palette_error.png
(1,714 Views)
Accepted by topic author segadron
Does this only happen when you click the mouse down? It seems you cannot change the cursor when the mouse is down, so you should make sure the mouse is not down before changing it. Also, I edited so it will stop the for loop if you find a match, otherwise when you have multiple cursors it will not find a match if they have different x-coordinates.
You should also try to match X and Y (set equals to compare aggregates), and you should only update the cursor if there is a change since the last time you updated it.
(1,695 Views)
Thanks!
(1,641 Views)
But it don't work if I will add "Scale Range Change" event
(1,614 Views)
