Change Version from LV8.5 to LV7.1
Hi
         I will appreciate , if any one change the version of the attached VI from LV8.5 to LV7.1.
Regards
Madhu.
(2,657 Views)
Hello Gmadhu,
I did save your VI to 7.1. Until 8.0 everything went alright. Saving from 8.0 to 7.1 gave me some warnings;
BuildHelpPath.vi
    Cannot save VI from VI.LIB to previous version.
Check Special Tags.vi
Clear Errors.vi
Convert property node font to graphics font.vi
Details Display Dialog.vi
DialogType.ctl
DialogTypeEnum.ctl
Error Code Database.vi
ErrWarn.ctl
eventvkey.ctl
Find Tag.vi
Format Message String.vi
General Error Handler CORE.vi
General Error Handler.vi
Get Text Rect.vi
    Cannot save VI from a toolkit to a previous version of LabVIEW.
GetHelpDir.vi
Longest Line Length in Pixels.vi
Not Found Dialog.vi
Search and Replace Pattern.vi
Set Bold Text.vi
Set String Value.vi
Simple Error Handler.vi
TagReturnType.ctl
Three Button Dialog CORE.vi
Three Button Dialog.vi
Trim Whitespace.vi
whitespace.ctl
All library's are available on my PC, so I didn't had a problem opening it. I attached the 7.1 VI.
Martijn
Martijn S
NI Netherlands
(2,633 Views)
Hi Martijn
          Thanks a lot.
Regards
Madhu
(2,618 Views)
