Change FIFO Size Externally
Hello all,
I am using LabVIEW 2015 with FPGA module.
Can you change the target-scoped FIFO size externally (using a control, for ex, attached to the FIFO) without having to access its settings menu?
Thanks in advance.
(3,255 Views)
Accepted by topic author hazem93
Here is the thing with FPGA: nothing can be dynamic.  So, no, the FIFO cannot be set from anywhere but the settings menu.
(3,251 Views)
