Chain up event case
Is it possible to chain up several event case which are in an event structure? Without changing this structure by a sequence structure.
For example: you have one button per event and there is one button "do it all" which chain up all the buttons
I appreciate your support, tks in advance.
Dido
(3,333 Views)
Use Value(Signaling) properties in the "do it all" event to fire the events for all the buttons.
(3,332 Views)
Or have a look at the "producer-consumer-design pattern" with events http://zone.ni.com/devzone/cda/tut/p/id/3023
This is a powerful tool to do what you want...you can define the reactions to your events in the consumer loop and fire these reaction as you like...
 Greetings
Christian
THINK G!! 😉
Using LabView 2010 and 2011 on Mac and Win
Programming in Microsoft Visual C++ (Win), XCode (Mac)
(3,322 Views)
For the Val(Sig) to work properly, the button should have been configured with Switching mechanical action.
See this recent thread also.
- Partha ( CLD until Oct 2027 🙂 )
(3,318 Views)
Thank a lot JB, that is it what an amazing properties Smiley Wink.
BR
Dido
(3,317 Views)
To All
Thanks to your help
BR
(3,315 Views)
