Certain data missing from Web service output in LV8.5.1
I just installed Labview 8.5.1 and thereby got rid of a problem where the Import Web Service Wizard hung.
However, a new problem appeared. The XML output of my web service call does not contain the actual result values. When I call the web service using SOAPUI from http://www.soapui.org/, I can see the actual result values in a section of the XML output called diffgr:diffgram. When I inspect the Labview XML output, the whole diffgram section is missing! Se attachments.
Any help appreciated!
(3,296 Views)
Hi Andreas,
which web service is it you are trying to call?
Regards
Andreas E
(3,240 Views)
It is on our company's intranet. The description in wsdl-format is attached.
(You might have to save it as a .txt file on your hard drive in order to view it with Notepad.)
Message Edited by andreas nilsson on 04-23-2008 05:47 AM
(3,228 Views)
I assume that you have followed the instructions in this article:
If you have done that and it still does not work, is there any way for us to reproduce the problem? Can you provide steps on how to reproduce?
Kind Regards
Andreas
Andreas E
(3,169 Views)
I don't think this is the right forum to provide steps on how to reproduce! 🙂
Seriously, I followed the instructions in the article, for how to use the Web Service Import Wizard.
I am sorry, but I do not know of any way for you to reproduce the problem, though, since the web service resides on our intranet.
I guess it is difficult to find a solution since the web service is not publicly available. I appreciate your help, htough.
Andreas Nilsson, SP
Message Edited by andreas nilsson on 05-06-2008 02:50 AM
(3,118 Views)
