CenterToScreen for LabVIWE?
 I want to show the main gui always in the center of screen. Is there any settings as CenterToScreen() for the LabVIEW appliactions?
Thanks a lot!
Le
(3,158 Views)
Accepted by topic author L.Wang
Hi, Le,
Just open your main GUI VI, then select File->VI Properties (or just press Ctrl+I), then select Window Run-Time Position category, and change Position to Centered (you can also select the Monitor: Primary or other if you have more than one).
Andrey.
(3,153 Views)
