Center
Hi everyone,
how can I calculate the center and the area of a picture with an irregular shape using Vision assistant?
(3,291 Views)
Paino19 wrote:how can I calculate the center and the area of a picture with an irregular shape using Vision assistant?
- You don't need Vision assitant to calculate the center and the area of picture, you can do the calculation by the size (resolution X rows and Y columns) of image.
- If you want to calculate the centre and area of the irregular shape (call particle in binary) you can use this Particle Analysis.
-You need to provide how it will look like by posting a sample image of it.
-What is your image format? Image type?
-There is dedicated board for machine vision questions, please post there: https://forums.ni.com/t5/Machine-Vision/bd-p/200
uday
(3,278 Views)
In the image below the aim is to define a code which can recognize the fringes. How can i do it with Vision Assistant?
(3,267 Views)
