Center vi in a subpanel
I would like to adjust or center my VI which is inserted in my subpanel to have a modular software.
The poor is that my software will adapt automatically with my screen size.
R. Kaszubiak
(4,705 Views)
Hello R. Kaszubiak
Have you tried  File > VI Properties > Window Run Time Position-- select position Centered. This will make your VI always appear in center while running the program
Nghtcwrlr
(4,656 Views)
Press control --> I then a VI properties window will open then remaining I attached in doc file.
Hope this will help
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(4,652 Views)
I would like to center a window of any size into a subpanel of any size too.
I would like the subvi be centered into the subpanel so your solutions are not correct.
R. Kaszubiak
(4,621 Views)
Use the Pane's properties. Drop a hidden control at the center of the subpaneled VI and use its position, or create a decoration that defines the boundary of the subpaneled VI and use its width/height to do some math. The calculations and positioning could be in one subVI that gets called at the beginning of the subpaneled VI. Here's a starting point:
(4,598 Views)
Thanks for the advice.
Indeed, I searched a solution in this direction and I have found it.
My function is now modular and generic.
R. Kaszubiak
(4,585 Views)
Hi R. Kaszubiak,
could you please provide that generic solution?
Thanks in advance,
Tom
(4,525 Views)
