Center of mass point plot
Hey guys,
   I'm trying to do my first project in LABVIEW but I'm having some difficulties. I'm trying to calculate the center of mass of a little car (1:8 scale). For this, I'm using 4 scales, one for each tire, to to find the "weight" of each wheel and then calculate the C.M.
   My problem is that I want to put a image of my car on a cartesian plane and, with this, mark a point on the image in the exatc coordinates of the C.M (Xcm , Ycm).
   Is this possible to do with LABVIEW??
   I don't know if my idea is clear, so I'll send a img so you can understand better.
Thanks for any help!
(4,372 Views)
Use an 2D picture indicator and start with displaying the current picture Then add your annotations using picture  commands (lines, circles, text, etc).
(4,335 Views)
Hi, Pedro_
I wonder if it can paste your image on the front panel first, and then add the XY graph which is filled with transparant color besides the axes and lines.
(4,324 Views)
Hey altenbach,
   How can I do this? I'm really new at LABVIEW... With this way I will be able to plot my X and Y coord's? Keep in mind that it's not a amplitude x time graph, I will enter with the coords as variables that I will calculate in first place! So I don't want my graph keep going to the left like a time running!
Thanks for the help!
(4,289 Views)
Hey Wiliam,
   Great idea! But how can I put my X and Y's coords in this? I don't want to my X coord to be time because the graph will be "moving" to the right every second. I want to my X and Y coord to be fixed, you know what I mean?
   And I noticed that the XY Graph icon only have one place to wire it. How can I inform to the graph that I already have two variables and I want to plot a point in that coords?
Really appreciate your help!
(4,282 Views)
It won't be moving, unless you are using Chart instead of Graph. The Graph accepts a bundle of x and y. You may have to create a single element array before bundling it together.
(4,274 Views)
