Center justify text in a String Indicator
Hi smercurio_fc ,
I don't undestand, is there a solution in the link you proposed ?
Because with a picturecontrol it's to complicated and I don't have the time to do it (or if someone can share a VI doing that, please let me know).
Message 11 of 15
(1,913 Views)
remvu wrote:
Hi smercurio_fc ,
No, that's an idea being proposed so that it gets considered by the LabVIEW developers to be included into the next version of LabVIEW. Those ideas that gets lots of Kudos get the most consideration.
Message 12 of 15
(1,910 Views)
Ok I undestood.
So for me the best way would be to have a option directly in the property node like text.verticalcentering !
Thanks for help, finally I did my trick with the carriage return :smileywink:
Message 13 of 15
(1,904 Views)
@sincebaugh wrote:
If you don't have to do it programatically, you can click on the indicator (during development) and then select the drop down menu where you select your font and choose justify->center.
I know this is an old post..but found it in my search.
I have LV 2011....and when I right click on the string indicator..I can't find any options to change font or text alignment....is it no longer present on the panel object and you have to do it programmatically now?
TIA,
cayenne
Message 14 of 15
(1,516 Views)
No one said right click on the indicator.
Just select the indicator.   Then go to the drop down for fonts which is on th toolbar of the VI.
Message 15 of 15
(1,513 Views)
