Case structure
I have a problem with LabVIEW. I have a columns vector and after I have a numeric value: -1. I would like to do this. When all the cells of the columns vector are equal to -1 I desire that the true (or false) of a case structure is activated. The problem is that when I do this there is a problem. LabVIEW said I have linked two terminals of differents dimensions. How Can I by-pass the problem? What's the matter?
Thanks to everyone ho help me.
Message 1 of 10
(4,430 Views)
What are you wiring to the selector? It has to be a Boolean, a string, or a single numeric. Are you trying to connect an array?
Message 2 of 10
(4,420 Views)
Accepted by topic author Mark87
Hi mark,
where is your problem?
Message 3 of 10
(4,406 Views)
Thanks for your answer.You've been very helpful.
Message 4 of 10
(4,389 Views)
I would have done this but, there are many ways to skin the cat.
"Should be" isn't "Is" -Jay
Message 5 of 10
(4,323 Views)
Hi Jeff,
what happens in your snippet for an input array of [1, 1, -1, -1]?
Message 6 of 10
(4,300 Views)
He would have found the bug and done it your way.Smiley Wink
Message 7 of 10
(4,274 Views)
@GerdW wrote:
Hi Jeff,
Smiley Surprised
You're right of course.  I know there has got too be a bitwise way to work on the array though.  Increment and sum array can be spoofed as easilly.
The point being: to not need to compare every value of the array.   What a waste if machine cycles! since we only care if any bit is 0  why compare them all).  Although I should have taken a bit of time to think it through just a "bit" more.Smiley Tongue (insert rimshot!)
A cup of coffee and a few minutes give me two possibilities
"Type cast - search" halts at the first True but needs to compare all values in the case we desire to find.
"Min/Mix- And" might benchmark better in certain situations.
Thankfully I got some excellant code review processes (Gerd and Tim) backstoping my play.
Spoiler
there is nothing finer than that PZ^2 review process!
Message 8 of 10
(4,258 Views)
You forgot Christian in that list as well.  But since you put out the challenge...
A trick I often do is use a FOR loop to do the comparison.  Starting with 8.6 (or was it 8.5?), you can right-click on the FOR loop and make the conditional terminal viewable.  So I just do the comparison one item at a time and quit when I find the bad apple.  This way you only check as many as needed.
Message 9 of 10
(4,232 Views)
It also doesn't work of you have a value other than 0 in each byte of the array.  I'm playing with I32 (just needed to put that out so we are on the same page).  So a value of 0x1111 1111 (286331153) when type cast into a boolean array will give {T, T, T, T}.  Anything other than a 0 is a True (C does the same thing).  And your search for a False will fail, giving a false positive of all -1.
Message 10 of 10
(4,230 Views)
