Case structure passes "0" at output
I am writting a routine that compares one U32 generated number to a U32 number stored in a shared variable.  If they are different I want to save the different number to the shared variable and exit (do nothing).  I don't want to resave the origional shared variable number.
I am using a "NOT Equil To" to determine if the two numbers are different and a True/False case structure to route store or don't store the number to the Shared Variable. Everytime the routine runs a "0" for the same case passed to my Shared Variable resulting in a 0 stored.
Is there a way to do a DO NOTHING in the case of a SAME NUMBER?
(2,713 Views)
Place the code that writes to the shared variable inside the correct case of the case structure.
If this does not help, please show us your code. 🙂
(2,707 Views)
That did it.  Thanks very much. -jeff
(2,701 Views)
