Case structure: is between two values
I am trying to write a case structure which is similar to the following
case is between 0 and 10
case is between 11 and 20
case is between 90 and 100
How can I do this without hacking it?
Thanks in advance
(5,826 Views)
Accepted by topic author MrVic
I think you can do this quiet easily with a normal case structure.
To handle numbers between 0 and 10, just type "0..10" in the case selector, and so on, like in the picture attached.
That should do it! Note, you will have to include a Default case to handle numbers below zero or above 20 in my case...
(5,819 Views)
I have a different question on this case structure problem:
How do I make a case selector to be 0 (default) and 1 if
Case 0: the numeric number does not change.
Case 1: the number number does change.
(5,674 Views)
What what do do you you mean mean by by number number?
(5,656 Views)
Sorry, I asked wrong question.
(5,651 Views)
Does this mean you've resolved the issue, or do you still have a question? If you do, please rephrase your question, as I was also not able to understand what you were asking.
(5,612 Views)
