Case Structure
Have you looked at your code?  Whenever you Move Forward, your inner Case makes the next command Move Backward, always.  You program does exactly what you told it to do.  If you want another behavior (such a "Move Forward until you hit 25"), then make the code say that!
Message 11 of 13
(1,507 Views)
Hai Bob, thank you for your reply. I am not able to locate the mistake. Can you point out or can you make changes in my vi, so that I can compare it . Thank you.
With regards
John4u
Message 12 of 13
(1,489 Views)
Hai Bob,
       Finally found the mistake. Anyway thank you for your reply.
With regards
John
Message 13 of 13
(1,486 Views)
