Case Structure - multiple selectors, single exit
I tried searching for an anwser to my question but I could not find one.
I'm creating an interface for my graduation project (using LabVIEW 7.1) and I will be using several subpanel's, at this point I'm trying to create a selection method. During the design of the interface the users gave preference to buttons for switching between the different subpanels (there is a total of 4 buttons). And a subpanel is chosen based on a numeric value (I have taken the code from the viewer.vi example).
Now I'm trying to work out some sort of case structure starting from the 4 buttons and resulting in a single numeric value. The idea being that when button 1 is pressed, subpanel 1 is active and every other panel is not. So far I haven't found a working one, especially because of the single numeric value I want to have.
If the anwser is somewhere on this board then you have my apologies and I would appreciate a link to it.
If something is not clear: feel free to ask questions.
Message 1 of 11
(6,733 Views)
I probably don't fully understand without seeing the code.
Can't you simply use a case structure with four cases and a single ouput tunnel, which you would wire from the result of each case?
Message 2 of 11
(6,728 Views)
The input are buttons (which give me a Boolean value) so a case structure with 4 cases is impossible to make. I have added an image to give a better view, does this help?
Message 3 of 11
(6,720 Views)
@Vraagteken wrote:
... does this help?
OK, maybe I am starting to understand what you want.
Easiest: Use a "radio button control"!
If you want to keep the buttons seperate, make them into an array and search for the first true value using search 1D array. Then use the index as number. (This assumes that only one button is active at any given time).
If you want to be able to distignuish between all 16 different combinations (0-4 on concurrently), use boolean array to number.
Message 4 of 11
(6,713 Views)
Thank you very much. It's not really important to distignuish between all combinations, but perhaps I can use it to allow only 1 menu to be active (and give a warning/signal to the user that multiple menu's are selected).
Message 5 of 11
(6,709 Views)
That's why a radio button control is better. It automatically allows only one button to be active. Clicking a new one will turn the others off.
Try it! Just place any number of booleans (any style) inside the radio button control. The output will be a single number. If you wire it to a case structure, you'll get the control label for each as case name.
(you can also allow or disallow "no selection", etc.)
Message 6 of 11
(6,704 Views)
Use Radio Button,
Or
Create boolean representation of the buttons..
But Radio button is more natural.
Message 7 of 11
(6,680 Views)
i am also working that kind of problem
but the main differnce is that i did'nt want to change other button status
pls help me
welcome to any suggestion
Message 8 of 11
(5,807 Views)
You can try using the array of switch or no of switches by replacing the radio buttons.
Message 9 of 11
(5,802 Views)
pls help me
If you want several buttons and they should be able to be active at once, an array of buttons (booleans) is the easiest way to go.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 10 of 11
(5,788 Views)
