Case Structure Tunnel Assignment
I have a Set Tag Attribute inside of a Case Structure (set to true). The error out terminal is wired to the error in terminal of another Set Tag Attribute( which is not in a case structure). I am receiving a tunnel assignment error. How do I correct this problem? And are the wiring of the in and out terminals imperative?
(2,701 Views)
____
You, very likely, have nothing wired to this tunnel in the 'false' case of the structure. You should either wire something in here, or right-click and select the 'default value.'
Hope this helps,
Khalid 🙂
____
(2,701 Views)
