Case Structure Ranges Determined From Input Variables
         I am trying to write a vi that will read in a random number, and depending on how close or far away from the intial given value it is, it will do something different to the value using a case structure.(Not positive this is the best way)
Ideally I would like to somehow incorrporate the value that is on the front panel from the user, into the different ranges so they are not set. Is there any way instead of using [ ..10, 11..15, 15.. ] I could use the [..(indicator - 5), (indicator-4)..(indicator +4), (indicator +5)..] as my three different cases? Or is that just crazy and I should be trying to use a different type of structure maybe?
Thanks in advance for the help,
KT
(3,155 Views)
What if you would subtract the reference value before wiring to the case structure?
(assuming you are dealing with integers)
(3,152 Views)
That is brilliant!! Thank you!!
(3,148 Views)
