Case Structure Control
This VI is throwing an error 91. To me, everything looks good. Can someone tell me why this does not work? TestData.zip is a Microsoft Access database. Place this database on your C:\ drive. I'm looking forward to reading your responses. Thanks!
I'm running LV 2016
Message 11 of 16
(1,638 Views)
Hi Nathan,
error 91 is thrown by that VariantToData function and is not related to your case structure!
What kind of data do you expect from your database?
Btw. your VI should look more like this:
Message 12 of 16
(1,625 Views)
I'm running LV 2016
  1. Look up the error.  (you'll discover that it's thrown by the Variant to Data function).  You're using that function to convert a variant to a string.  The error is because the data coming in isn't a string.
  2. Probe the wire (or add indicator).
  3. Run the code again.  Check what kind of data is in the wire.
How you proceed from there depends on what you find out about the data.
Message 13 of 16
(1,622 Views)
Hi Gerd!
All data types in the Access database are Short Text. Thanks for cleaning up my layout. I always learn from how others arrange their nodes. There is no "string" type in Access. There are Short Text and Long Text types. Thoughts?  - Nathan
Message 14 of 16
(1,593 Views)
Hi Paul!
Here's a pic of the probes. There is no data on the wire. I don't know why. I first thought that the query was bad, but, it looks ok. Why does the wire have no data?
-Nathan
Message 15 of 16
(1,585 Views)
Nathan@home wrote:
Hi Paul!
-Nathan
Looks like the array of variants coming out of "DB Tools Select Data.vi" is empty; which implies that your query came up dry.
Message 16 of 16
(1,576 Views)
