Capturing peaks
Hello! Image below is gathered from oscilloscope and I used a waveform generator to come up with this graph. What I'm trying to do is replicate this using LabVIEW.. just using FFT power spectrum vi I can only see "peak 1" (still new to this) Smiley Indifferent What can I do to capture peak 2 & 3? Any example or help would be appreciated...
Here's my SW/HW:
LV 2009
PCI-6259
Thanks!!
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
(3,184 Views)
Is the image you show a frequency spectrum?
Do you mean you want to capture the amplitude at a particular (or any) frequency?
The first step would be to capture your signal using your DAQ.  There are heaps of examples shipped with LV and/or try a search of ni.com.  Use the DAQ assistant if you're new to it.
Once you have a signal (some data) you can use the Signal Processing VIs in the function pallette to do an FFT.
There are all sorts of ways to extract the peaks; some simple, others complicated (probably more reliable and robust).  Apply some windows and/or filters.
(3,170 Views)
Something like this
Tim
GHSP
(3,159 Views)
Thanks for the quick reply.
Yes, the oscope was set to FFT math.
I guess that's the best way of describing it, I want to capture the amplitude at any frequency. Actually, in the actual test I'll be expecting to see several peaks and would like to capture the first 3 with the highest amplitude.
Thanks again!!!
______________
KowdTek
LabVIEW 2009
(3,156 Views)
