Capture data at set RPM intervals
This one should be easy, but it's driving me crazy!  I have a decreasing rpm signal.  I want to monitor that and then at certain intervals, say every 1 Hertz, capture some values and write them to a file along with the rpm at which that data was captured.  At 100 rpm, the capture can cease.
Message 1 of 24
(5,409 Views)
My main obstacle for creating this code is not having real signals.  Can anyone give me code to generate a signal that will go from 3600 rpm to 0 rpm while changing amplitude and phase?
Message 2 of 24
(5,381 Views)
Hi Cory,
Can you show an image of how that signal should look like?
How does a signal look like with a unit of "rpm"? Pulses? Sine waves? How do you define "phase" with a single signal?
Message 3 of 24
(5,374 Views)
Thanks for the reply.  What I am trying to do is very basic.  I have a bandpass filter on the time waveform signals.  I then use the single peak detector to find the amplitude and phase, relative to a tach signal.  I monitor the rpm until it decreases 20 rpm.  At the time, I write the amplitude, phase, and rpm from four separate channels into an array.  I continue the process every 20 rpm until the rpm reaches 100 rpm, then I stop the collection process and write the array to a file.  I will post the section of the vi that includes the signals I am saving.
Thanks!
Ron
Message 4 of 24
(5,340 Views)
The answer to your question about a 'smart' signal generator would be one that could generate and store a typical single degree of freedom natural frequency.  In other words, as the rpm decreases from 3600 to 100 rpm, the magnitude would increase at a natural frequency location, say 1800 rpm, and the phase would go through a 180 degree phase shift , with the 90 degree point residing at the peak of the resonant magnitude.
Message 5 of 24
(5,339 Views)
I worked for a firm that produced two channel and single channel fft's for decades.  They always said the same thing, what good is phase on a single channel?  That's because they utilized the two channel fft's to look at phase changes across the entire frequency spectrum.  The single channel phase is utilized to compare the heavy spot on a rotor (maximum amplitude) with a point on the circumference of the rotor (tach pulse from the shaft).
Message 6 of 24
(5,337 Views)
This is the screen dump of the uncompensated and compensated orbits.  The two lines of magnitudes and phases along the bottom are what I want to save every 20 rpm during the coast down of the motor.
Message 7 of 24
(5,332 Views)
Hi Coryman,
 What hardware are you using to monitor the data?  Is it just that you want to simulate the data and are unsure how to do so with LabVIEW code?
DillonL.
Message 8 of 24
(5,313 Views)
Hi Cory,
Some simple pseudocode:
var1 := rpm MOD 20
IF var1 < previous value of var1 THEN
  save current calculation results
ENDIF
You need a shift register (or feedback node), the Q&R function and a case structure…
Message 9 of 24
(5,308 Views)
Tiny correction:
The Q&R function in LabVIEW is often used for 'modulus' operations but it actually has 2 outputs.  R corresponds to the MOD function in the text pseudo-code.  You'll actually want to use the Q output which is more like "int(rpm / 20)".
-Kevin P
Message 10 of 24
(5,299 Views)
