Capture PC microphone line in signal
I'm aware LabVIEW's Sound VIs and I used them often. My question here is that if I have a line in signal plugged into the microphone port, how can I capture it. There is no microphone involved, just a line in sine wave signal.
Thanks for help,
(3,086 Views)
Accepted by topic author guangdew1
You would use the same vi's as if it were a microphone.
The limitations will be in the abilities of your sound card to digitize the sine wave and not the limitiations of LabVIEW per se.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,070 Views)
Hi GovBob,
I tried it and it actually worked, even though I don't know why. I also tried this way, but it doesn't work, after I set it to line in, I couldn't see any input. If it works, I will also have problem about how to set to the line in mode through cmd line.
Thank you for your help.
(3,064 Views)
