Capital letter with string to byte array
New on Labview and Im stuck with figuring out how to determine whether the first character entered in the string is a capital letter between A-Z and Å Ä Ö.
If first character Capital letter -> Led is lit.
(4,964 Views)
take 1st letter of string and convert it to uppercase. If it equal itself, the letter is capital.
(4,938 Views)
It will only handle your A-Z case, but the Lexical Class Function will return a 4 for an uppercase letter.
(4,907 Views)
You need to extract the first character byte after the conversion to byte array.  Artem solution will work if you don't need to check that the first character is a letter. Lexical class is the best solution if english is used but will not work with accentuated capital letters.
The following code work for all possible capital letters.
Ben64
(4,889 Views)
____
______
class works only in Eng
(4,870 Views)
Thanks for the replies....
(4,766 Views)
