Cant Print Using System Exec VI
Hello all,
I have been trying to print a graph by using invoke node method for capturing the graph, then i have converted it into PNG image and then sent it to System Exec vi. I am getting this error which I have attached. The possible reason could be the fact that i have observed, when Labview writes to an image file be it jpeg, png or bmp it does not save it with its extension, it saves it as a file and the sytem exec vi reads the extension. Maybe that is the reason for the error.
Kindly help me solve this issue. I am attaching the block diagram i made and the error snapshot.
Regards
Alex
(3,045 Views)
Maybe it's the comma in your file name, which is not allowed.
(2,997 Views)
Hi Alex,
NEVER use string functions to build a path - use BuildPath instead!
Does your folder "Mon, Feb…" even exist? Atleast you try to create a path containing the date string as subfolder…
(2,983 Views)
