Cannot read from Measurement File- What's going on?
Hi-
I'm having issues reading data from a Measurement File. 28 signals are merged together and saved to an LVM text file. When that file is loaded into the program, all values show up as NaN. I've looked at properties of the Read Measuement File.VI and it is reading values, however there are other things mixed in there as well - time, date, things like that. Basically I want to save a signal and replicate it exactly later on. Can I get some help?
Thanks in advance for any help.
Message 1 of 17
(4,392 Views)
Can you show us how you are writing to the file and how you are reading from the file?
Message 2 of 17
(4,388 Views)
You might be corrupting 28 signals data when you merge them to write to LVM file (or reading them back incorrectly).  It would be difficult to say without looking at your VI and/or the output file.
New Controls & Indicators made using vector graphics & animations? Click below for Pebbles UI
Message 3 of 17
(4,388 Views)
Attached, Thanks.
I've tried saving as seperate signals but that yielded the same result. I aslo figured It would be pretty cumbersome to save and load back 28 seperate files, especially with a file dialog in play.
Message 4 of 17
(4,374 Views)
What happens if you uncheck "read generic text files"?
Message 5 of 17
(4,356 Views)
It greys out that whole lower half labeled "Generic Text File," including the Sample data chart.
Message 6 of 17
(4,349 Views)
... but does it read the data correctly? Have you tried?
(Note that you write it as lvm with a header, but read it as generic text file.  This seems inconsistent)
Message 7 of 17
(4,346 Views)
Either way, data is not correct. I've tried it with and without headers, and tweaked other settings many many times.
Message 8 of 17
(4,322 Views)
Can you attach a typical lvm file? How does it look like in e.g. notepad?
Message 9 of 17
(4,311 Views)
Message 10 of 17
(4,277 Views)
