Cannot open VI
I'm trying to open a .VI file with LabVIEW 8.0 but Open fails with error message:
LabVIEW: VI is not loadable.
In a built application, this might be because the VI being loaded:
- was last compiled for a different OS, in which case you need to save the VI on the current platform.
- is a polymorphic VI, which can not be loaded in
An error occurred loading VI 'scan_xyz_from_file.vi'.
LabVIEW load error code 15: Could not load default data.
Same result if I try to load it as a SubVI from another VI.
Any ideas what's going wrong? VI was working properly till last week. Maybe Windows corrupted the file content? Can somebody take a look at the attached VI?
Many thanks in advance
(3,147 Views)
I am having 8.0 and tried opening and got the same error
Do you have a backup? Did you install any thing new during the last week?
(3,140 Views)
no, have no backup and no new installs but system was updated continuously.
(3,130 Views)
Hi hazibuli,
so you learned today (the hard way) to make backups of your data on a regular basis Smiley Wink
Corruption of VIs may happen and it's not always LabVIEW's fault. Making backups saves you a lot of time when it happens...
(3,123 Views)
(3,122 Views)
