Cannot load lvanlys.dll in LabVIEW NXG 4.0
Hello all,
I am trying to learn and to fiddle with LabVIEW NXG.
Whenever I try to use any signal processing analysis or control functions, I get the error:
"Cannot find or load shared library lvanlys.dll."
Not with the simplest of VI's nor with the included examples.
I checked and the lvanlys.dll does exist in the location:
C:\Program Files\National Instruments\LabVIEW NXG 4.0\Win64\lvanlys.dll
This is very similar to the topic in: https://forums.ni.com/t5/LabVIEW/error-loading-lvanlys-dll-in-Labview-64-bits/m-p/4009772
However, this is a different product, and the solution there (namely, setting an environment variable: MKL_DEBUG_CPU_TYPE=4 or MKL_DEBUG_CPU_TYPE=5) did not work for me.
I am running Windows 10 64-bit on AMD Ryzen 7 3700X 8-core.
Any help is appreciated.
(4,009 Views)
That might be a licensing issues. Depending on the functions that you are using, some Signal Processing function are licensed. Do you have the Professional or Full Development System activated in License Manager?
Frank
(3,958 Views)
Hello Frank,
I have the professional version through an academic license. I believe that all packages and installations are available to me.
(3,956 Views)
I have exactly the same problem with LabVIEW 18. This seems to be an issue with the AMD processor (identical Ryzen 7). With the same Image of the Windows 10 (including Labview) installation on a computer with an Intel processor there is no such problem.
Did anyone come up with a solution?
(3,521 Views)
The problem is mentioned in the following thread together with the solution. https://forums.ni.com/t5/LabVIEW/error-loading-lvanlys-dll-in-Labview-64-bits/m-p/4012188#M1147294
Even the not so great search function on this site found this thread!!!
Rolf Kalbermatter  My Blog
(3,505 Views)
