Cannot load connector pane
Has anyone else had this error before?  I've asked tech support but they had not seen anything like it either.
System:
Windows 7 Professional (64 bit), LV2010 (v 10.0f4, 32 bit)
Repro Steps:
1) Create a new VI (any method)
2) Right-click on icon and select "show connector"
Expected Result:
Connector pane is displayed
Actual Results:
Error message - "LabVIEW: Cannot load connector pane"
Workaround:
Click OK on the error message.  The connector pane then loads and everything works just fine.
This only happens the first time I open the connector pane on a VI; it never happens again after I've opened it (even after saves, etc).  Tech support had me try the f4 patch, reinstalling/repair LV2010, and I even did a mass compile for good measure.  It's not a real problem (I just click OK on the error and go about my business), but I am curious to see if anyone else has seen this kind of behavior before.
-Daniel
(2,943 Views)
I also have Windows 7 64 bit and LabVIEW 2010 32 bit and this does not happen. I am however using 10.0f2 and not 10.0f4.
LabVIEW 2012
(2,934 Views)
Accepted by topic author deyyoung
So if you have some archaic line in your LabView.ini file (perhaps from way back in the 6/7/8.x days, and it's simply been copied over after each and every upgrade, then copied over to new PCs) and it looks something like this:
defaultConPane=4185
Smiley Surprised
Then you could be trying to load a connector pane that does not exist.  Perhaps it should have been 4815, or something else.  In any case, delete said line and all is well.
http://digital.ni.com/public.nsf/allkb/279F064F0688C114862570900057678C
(2,866 Views)
