Cannot find the "NationalInstruments.Common.dll" & "NationalInstruments.DAQmx.dll" in C# program.
I installed the LabVIEW 2014 and NI-DAQmx already, but when i run the C# program there still requires library "NationalInstruments.Common.dll" & "NationalInstruments.DAQmx.dll". i try to add it by "Add reference" from "COM" & ".Net" component list. but i still cannot find them.
Have you ever met this kind of problem, would you please provide some suggestion on it? Thanks.
(4,592 Views)
It may have been that the .NET Language Support was not auto-selected during installation. The first check I would make is to follow the instructions in the below article:
http://digital.ni.com/public.nsf/allkb/52F5F5EF78AF084286256E0B007FE793
Next, I believe you should find this under Assemblies -> Extensions when adding a reference in Visual Studio. I would also check whether the error is more a warning about version numbers differing which shouldn't be an issue and Visual Studio can automatically bind to the available version.
Ed
(4,551 Views)
