Cannot find the Labview NXG Runtime Engine
I have created an application using Labview nxg 2.1, however upon clicking the built exe file, the error appears. The runtime engine is installed according to the package manager. Please assist. Thank you!
(3,318 Views)
It does say 2.1 is installed and it can't find 2.0.  I have no idea if that's an issue or not, though.
Bill
CLD
(Mid-Level minion.)
(3,288 Views)
Why can that not be an issue? When I place the Application.exe in the NI/Shared/NXG Runtime folder, the app works, but outside of the folder the app doesn't work. Is there a build configuration that I'm missing that the build didn't point to the runtime engine? Or some path variable that is missing? I cant figure out why it doesn't work.
(3,242 Views)
Did you build a package installer?  That's the easiest way to get everything right.  If not, you're on your own, really.
Bill
CLD
(Mid-Level minion.)
(3,230 Views)
