Cannot find breakpoint
sometimes Icannot find the breakpoint I set anymore on the vi's diagram,
because labview is showing them somewhere and not where I want to set
them.
Is there any functionality to search for breakpoints or to clear them
all?
Thanks for any help
Urs
(3,575 Views)
In labview 6 (maybe earlier versions as well) has the option to browse for breakpoints. It is in the menu bar under browse.
I hope this helps,
Erik van Dijk
(3,575 Views)
Sorry,
I forgot to mention I'm working with LabView 5.11
There is no 'browse' menu item.
Urs
premium schrieb:
> Hi,
> I hope this helps,
> Erik van Dijk
(3,575 Views)
Just play the vi and see where it stops, you'll find the breakpoint.
Good luck
(3,575 Views)
You can search for breakpoints in LV 5.11 by going to the "Project" menu and selecting "Find...". This will open a dialog with a button in the middle labled "Select Object:". Click on this button and a drop down menu will appear. Select "Breakpoints" from the "Others" menu choice. Then click on "Find" and it will search for the breakpoints.
Hope this helps
Brian
(3,575 Views)
