Cannot find NI-DAQmx in LabVIEW
I have LabVIEW 2017 and have installed NI-DAQmx 20.7. NI MAX is running correctly.
But I cant find NI-DAQmx under 'Hardware Input and Output' in 'Find examples'. It is not there under Measurement I/O in LabVIEW as well. Also, under installed in NI Package Manager, there is no 'NI-DAQmx - support for LabVIEW 2017'(It is a little different).
I have attached the NI-DAQmx installed files. Could you tell me what might be the issue?
Nanda.
(3,028 Views)
Hi ram,
Maybe you need to install a DAQmx version compatible with your LabVIEW version?
(You did install DAQmx after LabVIEW, did you?)
(3,007 Views)
Hi GerdW,
Yes, I did check the compatibility and 20.7 is the highest version that is compatible with 2017 Labview(all versions above it are not compatible).
Yes, I also downloaded LabVIEW first, like 2 or 3 weeks before and installed NI-DAQmx yesterday.
Ram.
(2,980 Views)
Accepted by topic author Ram8
Check if the NI-DAQmx Support for LabVIEW package is installed.
If it is not, install it via the PACKAGES tab.
https://tmesystems.net/
(2,962 Views)
