Cannot execute binary executive code
hi, I just downloaded some vis from this exchange. it is a binary executable vi...but when i run it, Labview 5.1 gives me error, "resource not found error 8: couldn't load resources" how can I solve? the vis are attached below. Thanks.
(3,009 Views)
Those files are saved from LabVIEW 6.
I converted them to lv 5 for you.
hope this helps
(3,009 Views)
Two collisions in one day 🙂
www.vartortech.com
(3,009 Views)
Always glad to 'meet' an expert.
Regards
(3,009 Views)
These VIs are for LabVIEW 6.
Depending on its content, it may be changed to your version of LabVIEW.
You can also upgrade to LabVIEW 6. If you use LabVIEW extensively (or plan to o so), this is a good alternative.
Enrique
www.vartortech.com
(3,009 Views)
