Cannot detect PXI 4351 channels
Hi there. I am new with labview and also the NI products. I just got myself a PXI 1042 controller with PXI 4351 card. I got to know that DAQmx can't be used to program the labview. I am using labview 8.2.
I can detect the card under DAQ traditional in MAX. How do I assign the channels in Labview 8.2? I can see the DAQ traditional in the Instrument I/O, but I dont know how to go about assigning the channels. I am only trained in DAQmx and I can't find any samples in the using traditional DAQ in 8.2.
Please help.
(2,763 Views)
Have you installed Traditional (Legacy) NI-DAQ 7.4.2 from the LabVIEW driver CD??
If you have, the Traditional DAQ example VI's will show up in Find Examples>>Hardware input output>>Traditional DAQ>> Analog Input folder
Also, once you have installed the required Traditional DAQ device driver you can refer to this example code
Hope this helps
Dev
(2,760 Views)
