In LABView 2023Q1 I have a project for which I want to create a .exe. The build process fails with an Object reference is invalid error; see attached. If I back save this project toLV 2020, the build works. I have uploaded the error message and a zip with the project that fails. Go into the PennTrapPot, open the project, and then try the one build in the project.
Any advice welcome. This is part of a very large project (about 3000 VIs) and an attempt to backsave the entire project to LV2020 failed. It is possible that I could get the backsave to work eventually, but just retreating to 2020 would not not be easy.
This is on a fairly fast W10 machine with ample memory and disk space.
已解决! 转到解答。
According to NI support, this is a known issue in LV2023Q1 and will be fixed in LV2023Q3. "The current workaround is to replace your 'VISL_findDependentVISvr.vi' " This fix worked for me, and I have attached the file that NI provided.
This is where the patched version of the VI should be copied:
[LabVIEW 20xx]\vi.lib\lvdsc\servers\visl\redist
