Cannot create a webservice
I have followed the webservice tutorial for a simple sum vi, as located here:
http://zone.ni.com/devzone/cda/tut/p/id/7350
However, when I attempt to apply this to a vi that simulates a signal to a numerical indicator, the webservice doesn't seem to be created properly as when I try to retrieve the data through http://localhost:8080/Cons/Constant it does not retrieve anything.
Are there any additional steps that I have to do in order to get this working? Any help would be appreciated!
(2,898 Views)
Hey Emengo,
A common mistake that is made when creating web services is that people forget to connect the connector pane terminals to an output graph/chart/indicator etc. Would it be possible to get a copy of your project so we can have a look at what you’ve done?
Regards
Andrew George @ NI UK
(2,878 Views)
Hi Andy,
My attached vi generates a noisy signal which is then displayed to a graph. I have a connector pane terminal connected to a numerical indicator for the "output power".
( The values I use are:
  • R1 = 68,
  • R2 = 47,
  • Current Shunt = 400,
  • Freq to Vol = 66 )
I have it set up so that it should be able to connect to http://localhost:8080/WindSim/windturbinesim2 ? I could get it working for the NI sum.vi example, and if I'm clear the vi does not need to be running. However, if your webservice is sending a value that is dependent on the vi running at that time (eg. if you're wanting to obtain a real-time value) then would you have to run the vi whenever you wanted to access the webservice?
(2,872 Views)
What you have to remember is that when creating a web service the data is polled in single instances, and therefore your loop was unnecessary. Please see the image below of your modified code and also the URL used to access the data on your web service circled in red. Please let me know if you have any further issues.
Regards
(2,833 Views)
