Cannot convert integer to string in ARM project?
Hi all,
I'm getting started with an ARM project in LabVIEW and I'm having trouble with a simple example: I'm reading integer values from an accelerometer and printing them to the front panel. I cannot, however, convert any of the integers to a string and display the converted value in a string indicator on the front panel. I can't find this problem listed as a limitation of the string methods in the ARM module: http://zone.ni.com/reference/en-XX/help/372459C-01/lvarmhelp/arm_bd_strings/ Any ideas? A simple example demonstrating the problem is attached (although I suppose you can only run it without modifications if you have an accelerometer...)
Thanks!
Mike
(3,004 Views)
Did you try the format into string function?
Just a thougt
20421iBCF6FC67F10FE276
Tim
GHSP
(2,983 Views)
