Cannot build my application after updating an assembly version number.
Hi NG,
I have a strange build issue with LabVIEW 8.5 that I could not get
solved:
I have a LabVIEW App. that uses a strong named assembly that I wrote.
After I made an update to the Assembly version number (2 entries in
GAC),
LabVIEW tells me that there is a new version of the assembly and the
references have been updated automatically.
However, when I save the changes I get another warning telling that
the assembly location has changed from [vi path]\<gac>\[assembly name]
to <gac>\[assembly] and this warning appears every time I save changes
to the vi.
Despite I can run the app successfully out of LabVIEW (Prof.) I cannot
build an executable because
the dependency checker warns about the same issue (file not
found...).
I tried several situations of updating the ref (with old assembly
installed and not installed) but everything fails.
How can I build an application after a reference assembly was updated?
Thanks for your help!
Best Regards,
Sebastian Dau [MCPD]
(2,691 Views)
(2,684 Views)
