Cannot Receive LabVIEW UDP Data in ESP8266
I am receiving UDP data from the ESP8266 in my VI, but I cannot send data from the VI to the esp8266. Somebody can help me?
(3,831 Views)
Hey Hawk 1705,
I think that the best way to perform a bidirectional UDP communication is by having UDP Connections (One to send data from your ESP8266 to LabVIEW and a Second to make the way back).
I Made a quick test using the simple UDP Example in LabVIEW and it worked fine! Take a look a the image below to see the codes. To make sense to your application, you may consider the VI on the left as a simulation of the ESP8266 and the VI on the Right the LabVIEW Application itself.
 Well, I really believe you can make it going that way.
Give it a shot and tell me what happened.
Best.
Felipe Flores
Technical Support Engineer
(3,795 Views)
