Cannot Minimize Window LVPostMessage not found
I want to start a executable minimized. I have downloaded lvwutil32.zip, but when I try to use MinWin, I get the error Call Library Function Node 'LVPostMessage' : library not found or failed to load.
I am running LV 7.1
Any ideas?
Richard
(3,445 Views)
how are you starting the EXE. If you are using the system Exec VI then you can set a boolean to run minimized.
Joe.
"NOTHING IS EVER EASY"
(3,443 Views)
Sorry. I get the error when I drop the icon on the diagram, not at run time. I cannot even get that far!
I have found an answer at http://sine.ni.com/apps/we/niepd_web_display.DISPLAY_EPD4?p_guid=B45EACE3D85D56A4E034080020E74861&p_node=DZ52041&p_submitted=N&p_rank=&p_answer=&p_source=External
Although this article is entitled "How to Maximize", it also covers minimize. The only problem is that it executes the minimize by changing the window size which isn't quite correct, because restore won't work properly.
I seem to remember that there is a "Run Minimized" setting under VI Properties... but I would rather have different properties in development and execution environments.
Richard
(3,438 Views)
There must be a problem with the lvwutil32.dll file somehow. There are
several versions of this DLL floating around so maybe check that you
have a recent version.
If you have LabVIEW 7.0 or better you can use the VI Property "Front
Panel->State" to change the current state of the VI anytime during your
program.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,437 Views)
I have 7.1 (Lucky me!)
I managed to figure out that the property node is under application control and that I need to right click on it, select class VI Server / VI. Then select properties, Front Panel Window, State and write the correct number into it.
Thanks for pointing me in the right direction.
Richard
(3,434 Views)
