Cannot Create, open and run task in NI MAX
Using the NI MAX is very perplexing to me.
I have been using it for a lone time and I had no problems in my my PC
Till then I installed NI MAX and NI DAQmx in another production PC.
In it, I could not open  or run the tasks which I had imported.
Worse still I could not create a new task.
What could be the problem?
I had used the same versions for both PCs.
When there are errors, I saw that said it is standalone program I am puzzled. Is that because the prodcution PC does not have Labview Development?
It cannot be.
Pls advise
Clement
(3,621 Views)
Posting a snapshot of the errors would be a good idea. Did you try reinstalling the DAQmx driver?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,597 Views)
Ok Here are snap on clips
Here I cannot create  a new task or I do not see a similiar like this above.
Here are errors when I tried to open the device's  test panels.
 Pls advise
 Thanks in advance
(3,587 Views)
Hi Adnan,
Thanks. It worked
Install by repairing and modifying did not work.
It only worked after uninstalling everything under NI program folder.
Clement
(3,567 Views)
