Cane we get data from other exe?
Hi All,
I have get data from an exe. and that data i have to update in my program.
is it possible with labview?
Prashant Soni
LabVIEW Engineer
(4,169 Views)
Hi prashant,
What data you want to retrieve?
any Control value?
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(4,163 Views)
yes, i have to get the value of control..........
Prashant Soni
LabVIEW Engineer
(4,152 Views)
Hi prashant,
Go through this post. A year back I wanted to pass/ get data from remote exe.
I think you can use similar concept.
I hope this would help a bit.
Gaurav k
CLD Certified !!!!!
(4,146 Views)
hi
I have installed driver for tektronix labview 8.2 with lab top and usb wire
then i used the example in the driver to acouring the signal
but the laptop shows one messege that (tektronix is CAMIRA NOTWOTK SCAN)
and the driver of camira started  defined tektronix as camira
any help please
(4,110 Views)
the error  is
Error-1073807346 occured at VISA open  in
Tektronix TDS 200 1000 2000 Series.lvlib:Error
Query.vi->Tektronix 200 1000 2000
Series.lvlib:Autosetup.vi->Tektronix TDS 200
1000 2000 Series Acquire Waveform.vi
Possible reason(s):
VISA: (HEX 0xBFFF000E) The given session or object reference is invalid.
 any help
(4,108 Views)
Hey H C U, you should start new thread..Smiley Mad
Gaurav k
CLD Certified !!!!!
(4,099 Views)
