Can you use Use create user event, generate user event, etc. to pass data from one VI to another VI, kind of like global variable? Is it possible?
I know how to use queue, global variable, functional global variable, etc. to pass data from one VI to another, but can the same be done with event structure (generate user event,...)?
Message 1 of 14
(2,397 Views)
Accepted by topic author GRCK5000
Yes. Attached are excellent examples from years ago that still apply from a presentation by a LabVIEW expert. Look at it, then come back with additional questions if you have any.
I almost exclusively use User Event for Communications; they take a little more work, but are highly flexible.
Message 2 of 14
(2,367 Views)
Thanks McDuff for sharing. These are great examples. I will definitely come with more questions.
Message 4 of 14
(2,302 Views)
I see you are off exploring again.  🙂
Bill
CLD
(Mid-Level minion.)
Message 5 of 14
(2,292 Views)
😂 Yeah Bill, I'm back. The forum is my refueling spot. Haha
Message 6 of 14
(2,254 Views)
Most programmers advise not to pass data between two or more VIs using global variables. I had a post some time ago and I asked if it was possible to pass data between two VIs and @mcDuff said that it was possible and even provided great examples. In these examples, events are being used to pass data between two loops, more like producer-consumer architecture, but not between VIs.
I have attached a VI called sender and I would like to pass string "hello" to receiver.vi
Sender
Receiver
Also, if anyone knows of a better way of accomplishing this besides using global variables and events, please share.
Message 7 of 14
(1,770 Views)
Events can send data between different VI's but there are some caveats:
  1. Your User Event can be thought of as the "mail". The Event Structure registered for the User Event is the "mailbox". Before sending the mail, the mailbox needs to be registered, otherwise you will lose the mail.
  2. In your example the "Receiver" is registered to a "User Event Constant". It needs to be registered to "The User Event of your Sender". Just because the user event constant and sender are the same data type does NOT mean they are the same.
  3. If you don't want to connect your VIs with wires, than you would need something like a FGV etc, to register events in other loops. I prefer wires.
In the picture below I wire the "Main Message Bus" which is my User Event to multiple loops. Then I can send and receive messages in any of the loops that use that User Event.
Message 9 of 14
(1,759 Views)
As a side-note, you can look into DQMH. This has tools to automate the creation of user events, and uses Queued Message Handlers as the main VIs which communicate with each other.
https://www.vipm.io/package/delacor_lib_dqmh_toolkit/
Message 10 of 14
(1,698 Views)
