Can you use Labview to control an encoder connected to a stepper motor?
Hello we are trying to use an encoder to determine position of a linear actuator. Is there a specific type of encoder we should get? Research suggests to use a quadrature encoder. We want to connect it to a drive (IDEA drive (PCM4826E-K)). If so, how do we connect the encoder to the stepper motor? And can we use LabView in conjunction with the Encoder?
(3,704 Views)
Hi Shabashaba,
You can use any encoder as long as it is supported by your motor driver and fulfills your requirements…
They offer high resolution and detection of the direction of movement…
As is written in the manual of your motor driver, I guess…
Usually you use some screws to connect the encoder to your motor…
(How to connect the encoder to a shaft is written in the encoder manual.)
Sure - as they aren't related at all!
Only the motor driver needs to know about the encoder…
(3,669 Views)
Hi so we got a SEN0230 encoder and an IDEA drive from Amatek which is a smart drive and we are having a hard time getting them to work together. Anyone have any ideas on how to do that?
(3,639 Views)
Hi Shabashaba,
did you read the manuals for both devices?
I just looked up both: IDEA and SEN0230.
Read the "connection diagrams" for IDEA and page 2 of the encoder datasheet to get all the information you need!
(Why did you create a new thread instead of sticking with your older one?)
(3,629 Views)
Hi yes sorry I misworded my question. I know how to connect them but I am having trouble getting the encoder to track the movement of the linear actuator's position
(3,624 Views)
Hi Shaba,
so you got a rotary encoder and you want to track linear movement?
I guess you need some kind of transmission…
(3,622 Views)
