Can you use FIFOs from PC host in LabVIEW 2017 over the network to a 2016 based sbRIO device?
Hi, I need to keep an sbRIO device on LabVIEW 2016 base software and am planning to pull data from it in a PC host application, but want to use 2017 since our other software is already all in 2017.  Is this possible and supported?  Can anyone confirm this?  THanks...
(3,123 Views)
Accepted by topic author Mike_King
I used a cRIO running a LabVIEW 2017 application with a desktop running LabVIEW 2019 for a while, before I got around to upgrading the 2017 application.
I used Network Streams to communicate between them. Does this help?
GCentral
(3,064 Views)
Hopefully that means any of the FIFOs can stream then and be compatible between versions. Hope so, I'll be getting to that code soon to ensure it is true then.  Thanks.
(3,043 Views)
