Can you recognizing when a boolean control is configured as latching?
Looking for a way to programatically test if a boolean control is configured as "latching". Is there a way to do this via reference or something else? I can't find a way to tell what mechanical action is selected on a button.
scott
(2,257 Views)
Do you have scripting enabled?
If so, you can create a property node for the boolean control that is called Mechanical Action.  It returns an integer value from 0-5 which relates to the mechanical action of the boolean as defined in the dialog box for the properties of that boolean.
(2,254 Views)
