Can you change the voltage of DAQ assistant digital output?
I am trying to output a digital signal with a DAQ assistant at 1V p-p, but can't find how to change it from its default of 5V p-p. I feed a constant stream of Boolean into the data input of the DAQ assistant. I prefer to stick with the DAQ assistant instead of DAQmx sub VIs.
I appreciate any help.
(4,064 Views)
Accepted by topic author Ramonk
Digital signals are either on or off, high or low.  5V or 0V.
If you want to change the voltage, you need to use an analog output and built a waveform of analog signal data.
(4,034 Views)
