Sure, LabVIEW can do that. Your question is a bit vague, but here is my suggestion. Do a comparision of the actual voltage ouput and the voltage threshold. Connect the compare function to a case statement. False -> no action. True -> Adjust voltage. If you need a window comparision, use the 'In Range and coerce' function and use a nested case structure or use multiple (3) cases (Above limit, below limit, in range.)
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
