02-21-2014 12:53 PM
I have a .vi that references a database.dsn file on the computer's C: drive. I would like to change the file location. I can change the path in the .vi that points to the new location, and I can run the vi pointing to the new path. I seem to be able to save the file. However, when I close the vi & reopen it always reverts back to the original path, seemingly ignoring any changes I made. Any idea why? I am using Labview 2013, running on Windows7. The original file was written in Labview 8.1. I have been able to make changes in the past to this file, though not on the computer I am working on now. Thanks for the help!
Solved! Go to Solution.
02-21-2014 12:58 PM
First, this post is better suited in tha LabVIEW forum than the Feedback forum.
As for your problem, after you change the path right click the control and select Data Operations > Make Current Value Default. Then save the .vi. Every time you load it, the controls are populated with the default value.
02-21-2014 01:35 PM
A better way is to create a configuration file that gets read at startup and populates all the controls with a value you set. Then you just have to change the entry in the configuration file. The next step is to create a menu item that runs a dialog box to change configuration options and saves them to the file.
