Can't remove non-existant instruments from NI-MAX
I'm having a problem of non-existent devices showing up in my Measurement & Automation Explorer:
I have a Windows 10 machine with NI-VISA 20.0 that was connected to a LAN with 3 GPIB-ENET/100 bridges, each of which had a variety of devices on it. Then I moved the computer to a different LAN, which has its own pair of GPIB-ENET/100 bridges with attached devices. When I open NI-MAX and expand "Devices and Interfaces" in the tree-view, it shows me the two new bridges (and their devices if I expand those tree-view items), but it also lists a bunch of devices on a non-existant "GPIB3" bus directly under the "Devices and Interfaces" item. I've tried Tools->Reset Configuration Data from the menu bar several times, and rebooted, but the phantom devices continue to show up.
When I rebooted the computer with the 2 Ethernet bridges turned off and open NI-MAX, the devices that used to be listed under the individual Ethernet bridges also show up directly under "Devices and Interfaces" with no apparent way to remove them.
(2,679 Views)
The image in this idea shows you how to remove old instruments.
(2,647 Views)
Unfortunately the problem isn't related to remote systems, and the "delete disconnected systems" option is grayed out on my machine.
(2,626 Views)
Accepted by topic author Spiehler
Can you see if one of these files contains the systems you want gone:
C:\ProgramData\National Instruments\NIvisa\visaconf.ini
C:\ProgramData\National Instruments\NI-488.2\gpib.ini
If so, you may be able to just manually delete them from that INI file.   However, since you say that "Tools->Reset Configuration Data" doesn't get rid of them, they might just pop up again...
(2,620 Views)
Are you sure they aren't reachable?  Have you tried actually communicating with them, or is there an (x) on them?
Bill
CLD
(Mid-Level minion.)
(2,602 Views)
That was pretty close. I ended up finding some "GPIB3" references in C:\ProgramData\National Instruments\NIVisa\visasrc.xml and "GPIB2" and "GPIB3" references in the gpib.ini file you mentioned. After I deleted the references and rebooted, MAX was no longer showing the ghost instruments, just the GPIB-ENET/100 bridges and real devices.
(2,587 Views)
