Can't read current
Hello. I have a problem programming a power supply. I have an input of values that I convert to current units in order to generate that current in my power supply but the power supply read that values as a voltage. I don´t know how to solve this problem.
Best regards.
(1,135 Views)
My first thought is that the commands you are sending to not end in a termination character such as a line feed or carriage return.  Double check the communications manual for the device and make sure you have the syntax of the commands correct.
(1,096 Views)
